07-03-2003 07:31 PM - edited 03-13-2019 12:35 AM
I was wondering if any/what kind of codecs are used connecting to the PSTN using a T1 MFT interface from a IP phone. I want to use an AIM-VOICE-30 with a 2600 router and I want to make sure I will have enough DSPs. The phones are all using G.711 compression.
Solved! Go to Solution.
07-07-2003 12:19 PM
DSPs are still used.
Yes, echo cancellation will still happen on the DSPs as well as any transcoding beween ulaw and alaw(if needed)
07-04-2003 07:59 AM
Digital PSTN connections are g711u.
07-07-2003 08:53 AM
So then there are no DSPs used? How about for echo cancelation?
07-07-2003 12:12 PM
07-07-2003 12:19 PM
