DTMF for BE
Hello
Or configuration: CCM 4.2 + gateway 2811 (BRI)
When we call a number which requires a choice in a menu, that does not function (example "Press 2 for French")
I think that it is a problem of DTMF.
I have download the Locale Installer to install BE
In the gateway, I have this configuration:
Voice-Port 0/0/0
Compand-type a-law
cptone C1
ccm-manager download-tones
When I do show ccm-manager download-tones I have BE for C1
A thing which appears odd it to me is that when I make Show ccm-manager download-tones C1, the PCM is u-law. In Europe one is in a-law
You have an idea?
Super Bronze
Re: DTMF for BE
Assuming you are using MGCP, you need the following command to pass DMTF.
Mgcp dtmf-relay voip codec all mode cisco
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: DTMF for BE
Yes, I'm using MGCP
No change with your command.
I add the config
203
