dtmf problem
Cant pass dtmf after call is connected.
ccm 3.3
2620 ios mgcp gateway
cas t1
help!!
Re: dtmf problem
Try adding the following global config command to your 2620:
mgcp dtmf-relay voip codec all mode out-of-band
Re: dtmf problem
thanks for the reply.
The problem ended up being in nortel op 11.
They did not have supervision turned on the cas tie trunk config
Go Figure!!
138
