DTMF relay with CCm and 3810
Having a DTMF issue here. Running CCM 3.1 with 6608 for PSTN. We also have various 3810's at different branches connecting via analog or T1 to Nortel PBX's. The DTMF relay (once connected) is not operating. Although the digits are passed successfully to place the call, DTMF for voicemail operations etc. are not working.
The 3810 is different (slightly) than 26xx series, especially in the DTMF-RELAY command whereby there is ONLY a dtmf-relay cisco-rtp option.
Here's a copy of the config: (Any help is appreciated!)
IOS Version: 12.2(12)
voice-port 1/1
voice-port 1/2
voice-port 1/3
voice-port 1/4
voice-port 1/5
voice-port 1/6
voice-port 1/7
voice-port 1/8
voice-port 1/9
voice-port 1/10
voice-port 1/11
voice-port 1/12
dial-peer cor custom
dial-peer voice 201 pots
destination-pattern 222....
port 1/1
forward-digits 4
dial-peer voice 202 pots
port 1/2
forward-digits 4
dial-peer voice 203 pots
port 1/3
forward-digits 4
dial-peer voice 204 pots
port 1/4
forward-digits 4
dial-peer voice 205 pots
port 1/5
forward-digits 4
dial-peer voice 206 pots
port 1/6
forward-digits 4
dial-peer voice 207 pots
port 1/7
forward-digits 4
dial-peer voice 208 pots
port 1/8
forward-digits 4
dial-peer voice 209 pots
port 1/9
forward-digits 4
dial-peer voice 210 pots
port 1/10
forward-digits 4
dial-peer voice 211 pots
port 1/11
forward-digits 4
dial-peer voice 212 pots
port 1/12
forward-digits 4
dial-peer voice 333 voip
destination-pattern 333....
session target ipv4:10.20.10.1
ip precedence 5
dial-peer voice 555 voip
destination-pattern 555....
session target ipv4:10.40.10.2
ip precedence 5
dial-peer voice 999 voip
preference 2
destination-pattern 2221...
voice-class h323 1
session target ipv4:10.0.1.100
ip precedence 5
dial-peer voice 998 voip
preference 1
voice-class h323 1
session target ipv4:10.0.1.101
ip precedence 5
dial-peer voice 444 voip
destination-pattern 444....
session target ipv4:10.80.10.2
ip precedence 5
Re: DTMF relay with CCm and 3810
It seems there is a bug with the CCM 3.1 and the 6608 line card w.r.t the DTMF relay.The one CSCdu13710 is the same as you have explained.You can get more details on this in the bug tool kit.I found some more bugs with CCM 3.1 w.r.t DTMF relay.
CSCdv88880
CSCdr86234
CSCdx18237
Might be, the problem will be solved with an upgrade on CCM.
Silver
It's not a bug on the Cat6k. The limitation is with the 3810's - the older style VCM (Voice Compression Module) based on the TIC542 DSP's did not have the CPU grunt to do H245 style DTMF relay. From the IOS release notes -
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120xk/1207xk/voip3810.htm#xtocid1950115
Note: The h245-alphanumeric and h245-signal DTMF settings on an MC310 concentrator require a high-performance compression module (HCM) and are not supported on an MC3810 concentrator with a non-HCM voice compression module (VCM).
You will need HCM DSP modules to run H245 based DTMF Relay
115
