DTMF to control Unity isn´t working
I have installed a Unity Voicemail System. Remote control of the voicemail boxes over DTMF from internal (IP Phones) is working. Remote control of the voicemail boxes from outside (PSTN) over DTMF isn´t working. I think it isn´t working because the DTMF tones aren´t transmitted to the Unity Server.
I have a cisco 3640 router with one e1 trunk to the PSTN, one Callmanager and one Unity Voicemail Server installed.
Has anybody an idea how to solve this problem?
Manfred
Re: DTMF to control Unity isn´t working
Sounds like you need to enable DTMF relay on your dial-peer to the unity. Under the voip dial peer, the command should be dtmf-relay h245-alphanumeric
hope this helps.
Thank you for your answer. This was my first idea too. The dtmf-relay h245-alphanumeric is configured on the dial peer voip and it doesn´t work anyway.
Manfred
Can you possibly post your 3640 running configuration? Also, what version of IOS are you using?
I haven´t found how to post an attachment. I have sent the config file directly to david. If everybody else needs the config file please send me an email.
Your symtoms closely resemble an issue I was having. Take a look at my dial peers....Use the progress_ind statements under your dial peers.....
dial-peer voice 1 pots
destination-pattern 9T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 2/0:23
dial-peer voice 2 voip
destination-pattern 6302...
progress_ind setup enable 3
session target ipv4:172.16.56.2
codec g711ulaw
no vad
I configured my dial-peers like your suggestion. But I still can´t send DTMF signals to the Unity Server. For testing DTMF I send DTMF signals from the PSTN to a IP phone. I think this should work.
No idea what to do!
You can just copy and paste the contents of the file to your post.
150
