DTMF with MGCP
I'm trying to figure out how to change the duration of DTMF digits for calls to the PSTN. We are using CCM 4.1(3) and all gateways are MGCP. Everything I've read says that the duration is fixed and cannot be modified. Aynone know any different?
Thanks, GLenn
Silver
Re: DTMF with MGCP
Did you get a chance try out the following voice-port commands
voice-port 1/0/0
timing digit
timing inter-digit
I am thinking it might help, because once the gateway gets the DTMF from the VoIP side, it would use whatever is configured under the voice port when sending the signal out that port. Never tested this though. Please post the results, if you get a chance to test this.
regards,
Anup
Re: DTMF with MGCP
Hi ,
I am trying to figure out how to change the DTMF duration in MGCP gateways as well, any idea?
cisco router is 2811 and 2651XM
542
