dual-line ephone-dn problem
We use dual-line ephone-dn to enable the users to transfer calls and
create conference calls.
The problem is that when the user is on a call and another call comes
in it uses the second line and rings until the no answer timeout and goes to
voicemail. We want it to go directly to voice mail if the user is on a
call.
Is this possible and if so how?
Scotty
Here is an example ephone-dn
ephone-dn 6 dual-line
number 3006
pickup-group 3086
label Test
description 3006
name Test
call-forward busy 3068
call-forward noan 3068 timeout 16
corlist incoming unrestricted
no huntstop
1 ACCEPTED SOLUTION
Re: dual-line ephone-dn problem
Huntstop channel command disables call waiting on dual-line ephone dns.
Blue
on your ephone-dn you want to add the command "huntstop channel"
number 3006
pickup-group 3086
label Test
description 3006
name Test
no huntstop
huntstop channel
This will allow you to have a dual line ephone-dn (for conferencing, transfserring) but if you are on a call and andother call comes in, it will route directly to voicemail.
please rate helpful posts.
adignan - berbee
119
