E&M incoming and outgoing
I have 8 ports E&M. 4 ports are used for incoming call. And the rest are for outgoing.
Can it be done?
What configuration should I add?
Re: E&M incoming and outgoing
Yes. Configure dial-peers that point to the 4 E&M ports you want to use for outgoing calls, and do not point any dial-peers to the ports you want to use for incoming calls.
Could you give me the sample configuration, please?
thanks
voice-port 1/0/0
description incoming only
voice-port 1/0/1
voice-port 1/1/0
description outgoing only
voice-port 1/1/1
dial-peer voice 1 pots
destination-pattern 2...
port 1/1/0
prefix 2
dial-peer voice 2 pots
port 1/1/1
prefix 2
163
