E&M paging, 2801 and CM 4.1(3)sr1
Hello all,
I have searched the past articles and not come up with an aswer for this one.
We have CM 4.1(3)sr1, Unity, IPCC, PA etc and all is well running through a 2801 equipped with:
VIC-4FXS/DID as 0/0/0 - 0/0/3 (fax & modem lines)
VWIC-1MFT-T1 as 0/1/0:1-16 (PRI)
VIC2-2FXO as backup PSTN failover (911)
We are trying to configure paging with an external amplifier using a VIC2-2E/M as 0/3/0.
A sh voice port summ at the 2801 shows 0/3/0 as e&m-imd when configured as in Cisco document ID 27627, however I'm at a loss as to how to configure callmanager route pattern to point to 0/3/0; when I attempt to configure the subunit 3 module of the 2801 gateway in Callmanager, there is no E&M module available.
At the 2801, "sh mgcp endpoint" shows the other module endpoints (POTS line, FXS lines for fax, and PRI lines) but not the 0/3/0 E&M endpoints.
Blue
Re: E&M paging, 2801 and CM 4.1(3)sr1
perhaps you should use an FXO for this connection.
this is how i have it setup in my offices.
as for e/m not showing up, check the show version to verify IOS shows the component as recognized. if it does not, check IOS version to see if it supports the component.
Thanks for the reply
The "sh ver" definitely shows up the two E&M ports, it's just in CallManager 4.1(3) that I cannot add the VIC2-2E/M module as a subunit to the 2801 gateway.
I'd really like to make this work but will concentrate my efforts on the free FXO port I currently have as it's being recognized (and therefore registered) by CallMananger.
181
