E&M to E&M connection
I have a problem on connection from E&M(HQ) to E&M(branches).
The connection between E&M(branch1) to E&M(HQ) is fail.
But when the call made from E&M(branch1) to
FXS(branch2) and HQ to branch1 can be done.
Can someone help me.
Re: E&M to E&M connection
I would need a little more information to help you out . What exactly are we dealing with ?
jkoniecki@yahoo.com
I'm using 3640 for HQ and 1750 for branches.
So then
PABX---(E&M)3640--
Hy Folks,
E&M Interfaces are used to connect PBX in case you cannot use an BRI-Interface. First of all please check if the E&M Type Version is configured well. Then you have to check the signaling Type as well. It can be either wink-,immidiate-, or ground-start depending on the PBX you are using. All these parameters must be the same on all E&M-interfaces (Router and PBX side) otherwise it won't work. Some PBX use different cable pinouts as the Cisco E&M Interfaces do. Please look at the links I send to you. Finaly if you have a serial connecten between HQ and branch1 please check if the dial-peers on both sides are configured well.
Links: http://www.cisco.com/warp/public/788/signalling/e_m_cab_pin.html
http://www.cisco.com/warp/public/788/signalling/21.html
Michael
Check the ff:
1. Wiring
2. Grounding, analog interfaces sometimes will not
work if not grounded. pin 8 of the E&M interface is
used for grounding.
3. Signalling ( wink or immediate)
4. Operation ( 2 wire or 4 wire)
Make sure all parameters are the same with the PBX.
Based on my experiences you need to start with the
wiring, almost all problems start from there.
http://www.cisco.com/warp/public/788/voip/voip_debugcalls.html
362
