E&M to Nortel Meridian Cut off problem
I have two E&M circuits connected to a Nortel Meridian PBX. Incoming/outgoing calls work calls work fine however after exactly 3 mins the call is cut off. I have looked at timers on the meridian and also the cisco router but cant see why this would happen. I have physically backed to back the circuits and they work fine with no cut off but as soon as they are reconnected i get the 3 minute cut off again. The circuits are 4 wire type1. Has anyone come across this problem?
colin
Bronze
Re: E&M to Nortel Meridian Cut off problem
actually had a report from one of my customers reporting the same issue and same configuration setup. the inital install had been working fine, but propogated itself after a few months. to date we did not resolve the issue. i left the company that did the install. ill try to call the customer to see if they resolved it and get back to you. id recommend you perform a debug voice ccapi inout, vpm signal and vtsp .
We can then trace the call flow and see whats going on from there.
hi
thanks for your reply, i am away from the office for a week so will do this when i return.
colin
121
