E&M Voice Interface + Radio over IP / IP over Radio Issue
Hi all, I've got a bit of an issue with a Radio over IP solution that I'm currently enginering in.
I've spent the past 2 days straight trying to work out what the issue is but have gotten to the point where I've burn't just about all bridges.
The situation is mentioned below:
The implementation is a "Twistpair WAVE solution" over "Cisco Architecture".
I've configured Wave with two channels, and all clients on the network can transmit/Receive between themselves. This means the Wave configuration is fine.
The Cisco router i'm using has a DSP module with 4 x E&M voice interfaces on the back. I'm using 2 of these voice interfaces for two seperate radio channels i.e... 1 x VHF and 1 x VHF/UHF radio.
The VHF radio is hooked up to the 1st E&M port using a Wave cable (AN/PRC-148) to RJ-45 adapter.
When transmitting off another 148, The 148 thats attached to the router keys, uses the DSP module to convert the analogue signal to digital, and all clients on the network receive the radio voice.
The issue lies with transmitting from the a client on the IP network, to the radio net on the outside. I cannot get it working the opposite way.
The Router configuration is below....
ip multicast-routing
voice-card 0
no dspfarm
voice service voip
h323
no call service stop
session transport tcp calls-per-connection 1
voice class permanent 1
signal timing oos timeout disabled
signal keepalive disabled
signal sequence oos no-action
interface Vif1
ip address 192.168.13.1 255.255.255.0
ip pim dense-mode
interface FastEthernet0/0
ip address x.x.x.x x.x.x.x
ip pim sparse-mode-dense
voice-port 0/0/0
voice-class permanent 1
auto-cut-through
operation 4-wire
type 2
signal lmr
lmr e-lead voice
lmr duplex half
no comfort-noise
timeouts call-disconnect 3
timing hookflash-in 30
connection trunk 1000
description VHF-CH
music-threshold -10
voice-port 0/0/1
auto-cut-through
operation 4-wire
type 2
signal lmr
lmr e-lead voice
lmr duplex half
no comfort-noise
connection trunk 1001
description VHF-UHF-CH
music-threshold -10
dial-peer voice 100 voip
description VHF-CH
destination-pattern 1000
session protocol multicast
session target ipv4:230.139.32.1:30002
codec g711ulaw
vad aggressive
dial-peer voice 101 voip
destination-pattern 1001
codec g711ulaw
vad aggressive
gateway
timer receive-rtp 1200
The VHF-CH and VHF-UHF-CH trunks appear when I transmit from radio to radio then into the IP network, but when I go to transmit from the IP network back out the radio channels in wave, the Radio does not key, so the audio isn't transferred.
Any ideas would be greatly appreciated. If it works one way, then the link is definately good.
Kindest Regards,
Andrew Hardy
Re: E&M Voice Interface + Radio over IP / IP over Radio Issue
I found the solution to the problem, with a bit of an electrifying experience in the process.
Touching the chassis that the router was mounted in, I got an electric shock. Frame was 97VAC to ground.(Can anyone say Random??...)
Removed the router and the problem dissapeared. Tested the power cable, the ground on the cable was non-existant due to suspected damage.
This problem in effect mean't that when the IP voice was transferring back to the router, where the Digital to Analogue conversion occurs, the E-Lead in effect wasn't providing enough voltage down the line to key the radio.
If I didn't get the shock, the problem would have still been there and potentially could have caused a lot more damage to both the equipment in the rack, and to technicians such as my self.
Thought i'd post this fix, as you never know when a similar issue could arise.
Andrew.
Hi Andrew
I'm very interested in what your doing and am looking into trying somthing similar myself. Would you be able to email me at jamie398@googlemail.com to dicuss further. Thanks Jamie
1785
