12-10-2005 02:48 AM - edited 03-13-2019 11:31 AM
HI There,
running a 1760 CCME to PSTN via Bri (IOS 12.3(14)T5)
Just got an E1 VIC to do a trunk to a mitel PBX (3300) using QSIG
However I can seem to configure the timeslots, it seems to require the
"tdm clock e1 0/0 both export line" but when entered I get "% exceed
the max 1 clock source limit" when I issue the commands.
Is this because I have "TDM clock bri-auto" already?
How do I get both working?
THANKS!!!
Peter.
12-16-2005 07:41 AM
Only one clock source can be used to provide clocking for the router. If the clock is not configured, the port will not communicate with the network.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/1700/1700cnts/tdmdesc.htm
12-18-2005 06:45 AM
I got it working eventually - the method differs from all the configuration examples & docs I've seen. If anyone is interested you need the global command:-
tdm clock E1 0/0 both import onboard internal
There is no 'clock source' command on the e1 controller as normal.
