02-22-2009 07:41 AM - edited 03-13-2019 06:06 PM
I need to know the E1 cable length limitations,in meters? Actually i've a customer who needs to extend their E1's from the basement to DataCenter Room and you people know the UTP Cable limitation. So which type of device should i refer to them for this purpose.
02-22-2009 09:19 AM
UTP gauge 22, typical attenuation, should cover 1000 feet ( > 300 m) without problem.
Make sure you use proper cable and respect the pair twisting, that is NOT like ethernet.
02-22-2009 09:47 AM
The distance is around approx 500 meters. What did u think ? It will work or not ?
02-22-2009 09:53 AM
Should not work. You can use a pair of hdsl modems/extenders.
02-22-2009 09:23 PM
Do you refer any hdsl extender model?
02-23-2009 05:51 AM
Yes.
