Bronze
E1 signaling (Telmex) - do i need custom options?
Trying configure E1 (Telmex is provider).
This is what I have so far:
controller E1 0/0/1
framing NO-CRC4
clock source line primary
ds0-group 1 timeslots 1-15 type r2-digital r2-compelled
Do I need cas-custom command?
Please let me know if you know working config for Telmex.
Thanks.
Green
Re: E1 signaling (Telmex) - do i need custom options?
Yes, you will need custom options,
controller E1 1/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country telmex
category 2
answer-signal group-b 1
caller-digits 4
groupa-callerid-end
description TO TELMEX
You may add the cptone mx under the voice port
//G
Bronze
Tried that and did not work until rebooted router. Running CME4 on 2851 12.4(4)XC. I think 12.4(4)CX is very buggy.
Green
Ok, if u still encounter issue you may open a TAC case with us.
538
