Community Member
E1R2 outgoing international calls problem
I have a dilemma with one of my client. It's a newly deployed CME system with an E1R2 connection to the telco.
Now the E1R2 config on the router is fairly basic and this config has been known to work with other carriers. But for this particular carrier, international outgoing calls are failing while local calls are fine.
This carrier claims that the Cisco router on our end is not sending an "End digit" when dialing international. It does so on local calls, however. I have to admit that I'm not really good at telco technologies and would appreciate any help from you guys.
Attached is the R2 Trace they sent me, comparing a successful local call and a non-successful international call. Any inputs appreciated.
Thanks!
Community Member
Re: E1R2 outgoing international calls problem
Attachment here:
Hall of Fame Super Gold
the trace is clear.
Would need see: exact IOS version used, config under controller E1 (the R2 stuff), and the dial-peer(s) used for domestic an international.
Also it would help very much a trace taken from the router, with "debug vpm signal" and "term mon".
Community Member
Appreciate the response.
The IOS is 12.4(15)T or T1. Not 100% sure.
Here's an excerpt of the config:
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-15 type r2-digital r2-compelled ani
ds0-group 2 timeslots 17-31 type r2-digital r2-compelled ani
voice-port 0/0/0:1
connection plar 500
voice-port 0/0/0:2
connection plar 500
dial-peer voice 500 voip
session target ipv4:10.0.0.1
codec g711ulaw
no vad
dial-peer voice 101 pots
dial-peer voice 102 pots
destination-pattern 9T
clid network-number 027935300
port 0/0/0:2
The creation of two DS0 groups was suggested to me by a colleague because when I configure a single DS0 group (ie. ds0-group 1 timeslots 1-15,17-31... etc), I can't make ANY outbound calls. Incoming works, however.
Hi, you do not have ANY customization like "country", for your R2 config. It is already fortunate that it works partially!
If you mention country and carrier, chances are one working template can be found.
Community Member
Will try that. Thanks.
182
