Easiest way to monitor PRI usage
What's the easiest way to monitor an H.323 gateway for PRI circuit usage and log instances when all circuits are busy? I have the gateway logging to a syslog server now. Is there an extra mib I can load on the gateway that will kick off a trap when all circuits are in use?
Or alternatively I thought about using CDR records. Is there a report in CAR that will give me max simultaneous calls perhaps?
any suggestions would be welcome.
Re: Easiest way to monitor PRI usage
I never had much success with the MIBs here. This is one of the benefits to upgrading to MGCP. You can run perfmon on windows to get all of these stats.
And what about the Cisco H323 - CallsInProgress counters from perfmon or realtimemon???
sascha
202
