Easy question - SQL
What SQL 2000 Service Pack is required for CCM v3.3?
Lee
Gold
Re: Easy question - SQL
Service Pack 2 is the minimum I believe, but it may have been updated to Service Pack 3a with the advent of 3.3(3) or 3.3(4). The relevant service pack gets loaded along with the CallManager install. Due to security and other issues Service Pack 3a plus the hotfixes are highly recommended for ANY CallManager 3.3 deployment. These updates are available from CCO along with the rest of the operating system updates.
Thanks jasyoung,
So the software requirement for any CallManager installation should be:
Windows 2000 Server
SQL 2000 Server (with Service Pack 2 minimum, SP3a recommended)
Thanks greatly for your help,
Lee
Thanks jasyoung,
Windows 2000 Server
Lee
Not sure of the reason for the question b/c SQL gets installed with CallManager, not separately. SQL2000 SP3 is installed with CallManager 3.3
126
