m
Echo problem
IP phone user hears an echo of his voice on a call to a PSTN phone. It looks like an issue with the voice gateway. Checked the cisco document
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080149a1f.shtml
Set the echo canceller converge to the highest value (64ms). But the users are still experiencing echo problems.
Attached pls find the output of "show voice active".
IOS 12.4.6T on Cisco 2811
Appreciate any input.
m
Re: Echo problem
voice-port 0/0/0:15
input gain -3
output attenuation 3
cptone AU
Re: Echo problem
There is a known bug with that version of IOS and the DSPs on it...bug CSCsd54344
DSP: Persistent echo heard on c5510 DSPs with 4.4.13 DSPware or higher
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsd54344
use show voice dsp group all to see if it is using DSP version 4.4.708. If it is you either need to go up to 12.4.9T (first fixed version) or downgrade the DSP (easiest option) to version 4.4.706.
You can call TAC about getting that file if needed.
131
