12-20-2001 05:14 AM - edited 03-12-2019 01:48 PM
Running CallManager 3.0(11) and using Cisco phone 7940 & 7960, our customer suffers echo problems. What load would provide the least echo these days :v) Is there a place to search for this, or is it answered via TAC in every case ?
Regards Jan
12-20-2001 05:28 AM
Jan,
Do you have echo problem between IP phones or IP phones and PSTN ?
Duc
01-02-2002 05:18 AM
Hi Duc,
Sorry about the delayed answer, here it is. Our customer has echo between IP phones and the PSTN. It vary'es from time to time, and effects about 50% of the calls in and out of the house
Jan
01-02-2002 10:59 AM
What gateway and protocol is in use? You can increase the delay window on the echo canceller and eliminate the echo in most cases.
Pat
01-03-2002 05:49 AM
The gateway is 3600 running IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(5.4), connected via a ISDN PRI.
The protocol is G.711
I tryed ajusting the echo delay, as well as the signal levels, as recommended in this forum, but it's not to the customers liking.
Jan
