Echo when users calls certian sites??
I have users complaining that when they call certian sites they get a bad echo. I have an ISDN PRI going out.
What is the echo-cancel coverage command? Will it help with this? and do I load it on the T1 controller to the voice port 1/0:23 ??
1 REPLY
Re: Echo when users calls certian sites??
You have to enable it, then adjust the coverage size with this command. Check out the command reference: http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t3/voip5300/voip53_2.htm#xtocid16583134
90
