Community Member
emulator for 7940, 7960 & 7970
Hello All,
I need a emulator to help me to develop a application in 7970 and 7960.
Where I can get the emulator for these devices?
Rodrigo.
Re: emulator for 7940, 7960 & 7970
Considering all the issues with different phone loads and the likes the only reasonable suggestion can be to use physical phones. There's an old piece of software that emulates the 7960 (don't recall the name but if you search old posts you should find it), and as far as the 70 goes, the IP Communicator is a close equivalent. Still, it could be fatal if you use software phones to test an application that your client is going to use on hardphone.. make sure you plan on plenty of testing on real phones.. there's simply no alternative.
Community Member
Thanks Stephen for you reply.
I dont have a 7970 yet.
Is it possible to test using ipcommunicator?
Is there any feature that ipcommunicator doesnt have?
Thanks fo your help.
Rodrigo.
If you're not working for a Cisco Partner, get in touch with one.. they can sell you an IPC (there's no demo licenses and you need a call manager anyway). Compared to the phones, it's quite reasonably priced. I'm not sure if they have a program to get hardware for a reduced price for development purposes (there's one for partners.. but it's forbidden to resell hardware acquired under this program to anyone). But be aware that while the IPC is a good testbed to incept your applications, you have to switch to hardphones at some point. I use the IPC quite often on the road, at home and a customer sites, but it doesn't always act the same as a hardphone.
734
