Enable IPCC Application from web
I want to create an IPCC application with multiple applications inside. Each application is an IVR application to handle calls, depending on the situation (emergency, closed, holiday) for our Call Center. I want to be able to switch between IVR apps, if possible from a web interface. Is this possible and if not, what is the best way (if at all) to do this?
  • Other Collaboration Voice and Video Subjects
Re: Enable IPCC Application from web
IPCC express???
You can create a script with desicions made on booleans (true or false), and if you make them a parameter you are able to change the true/false on the fly from the appadmin pages (manage applications)
and first new caller will get this "new" script and go to a emergency state....
(so create 1 script with multiple applications in it, all with different labels, and just "goto" a label if i.e. emergency = true...)
hope this helps!
Sascha
Hello Sascha,
Thanks !
Cheers,
Cas
You're welcome Cas!
91
