10-28-2005 12:01 AM - edited 03-13-2019 11:01 AM
Phones can call externally via router w/ISDN module with any problem.
Debuging Q931 I am not able to use ISDN TEST CALL. Is it a case of enabling that option?
10-28-2005 12:11 AM
You could use the hidden:
csim start
To test calls, subject to all your dial-peers and so on as a real call is...
Aaron
10-28-2005 01:47 AM
Thanks, it works, but is there any way to check single interface?
10-28-2005 04:15 AM
I don't think there is with that command...
What happens with the test isdn command? Is it just not there?
I think some versions of software have
test isdn call
instead of
isdn test call
Have a look...
Aaron
p.s. please rate helpful posts.
