Encounter Input Error at Serial Interface :15
Hi All,
I having a AS5300 connected to a ISDN PRI E1, but when i start sending voice calls into the AS5300, alot of call cant connect, i have did a sh Int serial 2:15 and find that there is input error.
Can anyone help me to solve this problem?
here is the info from the GW
Serial2:15 is up, line protocol is up (spoofing)
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
reliability 128/255, txload 1/255, rxload 1/255
Encapsulation HDLC, loopback not set
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 04:46:55
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
5 minute input rate 0 bits/sec, 9 packets/sec
157983 packets input, 1271719 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
157974 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 157974 abort
158162 packets output, 1770073 bytes, 0 underruns
0 carrier transitions
Timeslot(s) Used:16, Transmitter delay is 0 flags
1 REPLY
Bronze
Re: Encounter Input Error at Serial Interface :15
The link is very impure, so you have to check the link quality.
78
