Community Member
Enu_Enu_UninstallDefaultDatabase.dcs?
What senarios would cause us to need or want to run the ENU_ENU_UninstallDefaultDatabase.dcs (with ConfigMgr.exe)with build 2.4.6.135? <br><br>
1 REPLY
Anonymous
N/A
Re: Enu_Enu_UninstallDefaultDatabase.dcs?
you probably wouldn't... if you were going to run that (which removes most of the Unity stuff from the directory) it would mean you're uninstalling Unity and you'd be much better off running the Uninstall application to get everything off and prep for a clean reinstall.
Frankly I'm not even sure why that DCS script still ships... it used to be used with the now-departed "reinstall" option offered by the Unity setup.
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
106
