Equivalent to "Attendant DN" using H.323?
I'm setting up a FXO test environment in which I must use H.323. I can call IP->PSTN (users dial 8 then the PSTN number of their choice) with no problem, but how do I configure the equivalent to an MGCP gateway attendant dn so that I can make calls PSTN->IP?
voice translation-rule 1
rule 1 /^8/ /9/
voice translation-profile 8to9
translate called 1
voice-port 2/0/0
caller-id enable
dial-peer voice 2999 voip
translation-profile incoming 8to9
destination-pattern 2...
session target ipv4:10.41.5.30
dial-peer voice 1 pots
destination-pattern 9T
no digit-strip
port 2/0/0
Bronze
Re: Equivalent to "Attendant DN" using H.323?
add the "connection plar xxxx" command under the FXO voice port, where xxxx is the number of the attendant
So:
Voice-port 2/0/0
caller-id enable
connection plar 2000
would ring extension 2000
Thank you for the quick response. I've now done exactly as you suggested but get a busy signal. The phone I've chosen (2304) is definetly up and can make calls IP->PSTN. Do you see anything else incorrect with my config? Thanks!
Blue
In CallManager, does the Inbound Calling Search Space assigned to your gateway contain the partition your 2304 phone is in?
adignan - berbee
I have no call search spaces or partitions set up in my test environment.
I don't know if this helps, but here is the "sho call active voice" from a call made PSTN->IP
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 1
GENERIC:
SetupTime=-2142302966 ms
Index=1
PeerAddress=
PeerSubAddress=
PeerId=1
PeerIfIndex=15
LogicalIfIndex=9
ConnectTime=0 ms
CallDuration=00:00:00 sec
CallState=3
CallOrigin=2
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0xF124E589 0xCB2511DA 0x8151D3A4 0xD904EA96]
IncomingConnectionId=[0xF124E589 0xCB2511DA 0x8151D3A4 0xD904EA96]
CallID=560
TxDuration=0 ms
VoiceTxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
OutSignalLevel=0
InSignalLevel=0
InfoActivity=0
ERLLevel=0
SessionTarget=
ImgPages=0
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=
OriginalCallingOctet=0x0
OriginalCalledNumber=
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=
TranslatedCallingOctet=0x0
TranslatedCalledNumber=2304
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
DSPIdentifier=2/1:1
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 1
Silver
Well, this shows the pots call leg just sitting there - I think we need to see a debug voip ccapi inout to see if the call ever actually gets sent towards the CM.
Mary Beth
Mary Beth,
The debug voip ccapi inout output is included between this post and my next ... thank you! Chris
2d21h: //-1/0640C8F6800B/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=2304
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0
2d21h: //-1/0640C8F6800B/CCAPI/cc_api_call_setup_ind_common:
Interface=0x64AF1ECC, Call Info(
Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentatio
n=Allowed),
Called Number=2304(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subsriber Type Str=RegularLine, FinalDestinationFla
g=TRUE,
Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Ca
lling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=-1
2d21h: //-1/0640C8F6800B/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Present
ation=Allowed)
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presen
tation=Allowed)
2d21h: //9/0640C8F6800B/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, P
resentation=Allowed),
Called Number=2304(TON=Unknown, NPI=Unknown))
2d21h: //9/0640C8F6800B/CCAPI/cc_process_call_setup_ind:
Event=0x64ABC140
2d21h: //9/0640C8F6800B/CCAPI/ccCallSetContext:
Context=0x63F45818
>>>>CCAPI handed cid 9 with tag 1 to app "_ManagedAppProcess_Default"
2d21h: //9/0640C8F6800B/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
2d21h: //9/0640C8F6800B/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=FALSE, Mode=0,
Outgoing Dial-peer=2999, Params=0x63F464A0, Progress Indication=ORIGINATING S
IDE IS NON ISDN(3)
2d21h: //9/0640C8F6800B/CCAPI/ccCheckClipClir:
ation=Allowed)
tation=Allowed)
Destination Pattern=2..., Called Number=2304, Digit Strip=FALSE
n=Allowed),
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=0640C8F6-CD6E-11DA-800B-993E309A01CB, Outgoing Dial-peer=2999
2d21h: //9/0640C8F6800B/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=2304
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
2d21h: //9/0640C8F6800B/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x64854F54, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened,
Presentation=Allowed),
Called Number=2304(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subsriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer
=2999, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl
ication Call Id=)
2d21h: //10/0640C8F6800B/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
2d21h: //10/0640C8F6800B/CCAPI/ccCallSetContext:
Context=0x63F46450
2d21h: //9/0640C8F6800B/CCAPI/ccSaveDialpeerTag:
2d21h: //10/0640C8F6800B/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x63F53D74, Call Id=10
Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
2d21h: //10/0640C8F6800B/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
2d21h: //10/0640C8F6800B/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=10
2d21h: //10/0640C8F6800B/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=38)
Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
2d21h: //10/0640C8F6800B/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x63F53D74, Tag=0x0, Call Id=10,
Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
2d21h: //9/0640C8F6800B/CCAPI/ccCallDisconnect:
ause=0)
2d21h: //9/0640C8F6800B/CCAPI/cc_api_get_transfer_info:
Anyone? Please!
Hi !
Now provide please output for debug h225 asn1.
As requested (broken between three posts):
5d17h: //-1/A6281F7C8021/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=2304
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
5d17h: //-1/A6281F7C8021/CCAPI/cc_api_call_setup_ind_common:
n=Allowed),
g=TRUE,
E), Call Id=-1
5d17h: //-1/A6281F7C8021/CCAPI/ccCheckClipClir:
ation=Allowed)
tation=Allowed)
5d17h: //37/A6281F7C8021/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
5d17h: //37/A6281F7C8021/CCAPI/cc_process_call_setup_ind:
Event=0x64ABD110
5d17h: //37/A6281F7C8021/CCAPI/ccCallSetContext:
Context=0x63F488F8
>>>>CCAPI handed cid 37 with tag 1 to app "_ManagedAppProcess_Default"
5d17h: //37/A6281F7C8021/CCAPI/ccCallProceeding:
5d17h: //37/A6281F7C8021/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=2999, Params=0x63F49580, Progress Indication=ORIGINATING S
IDE IS NON ISDN(3)
5d17h: //37/A6281F7C8021/CCAPI/ccCheckClipClir:
ation=Allowed)
tation=Allowed)
n=Allowed),
Guid=A6281F7C-CFAA-11DA-8021-993E309A01CB, Outgoing Dial-peer=2999
5d17h: //37/A6281F7C8021/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=2304
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
5d17h: //37/A6281F7C8021/CCAPI/ccIFCallSetupRequestPrivate:
ication Call Id=)
5d17h: //38/A6281F7C8021/CCAPI/ccIFCallSetupRequestPrivate:
5d17h: //38/A6281F7C8021/CCAPI/ccCallSetContext:
Context=0x63F49530
5d17h: //37/A6281F7C8021/CCAPI/ccSaveDialpeerTag:
5d17h: H225 NONSTD OUTGOING PDU ::=
value H323_UU_NonStdInfo ::=
version 18
protoParam qsigNonStdInfo :
iei 28
rawMesg '1C399E0100036774640000002E49414D2C0D0A47...'H
progIndParam progIndIEinfo :
progIndIE '00000003'H
5d17h: H225 NONSTD OUTGOING ENCODE BUFFER::= E0011200011C3B1C399E010003677464000
0002E49414D2C0D0A4743492C6136323831663763636661613131646138303231393933653330396
1303163620D0A0D0A088006000400000003
5d17h:
5d17h: H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
h323-uu-pdu
h323-message-body setup :
protocolIdentifier { 0 0 8 2250 0 4 }
sourceInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
activeMC FALSE
conferenceID 'A6281F7CCFAA11DA8021993E309A01CB'H
conferenceGoal create : NULL
callType pointToPoint : NULL
sourceCallSignalAddress ipAddress :
ip '0A2A1E02'H
port 29458
callIdentifier
guid 'A628BBA4CFAA11DA8023993E309A01CB'H
fastStart
'0000000D4001800B050001000A2A1E0249F780'H,
'400000060401004D40018012150001000A2A1E02...'H
mediaWaitForConnect FALSE
canOverlapSend FALSE
multipleCalls TRUE
maintainConnection TRUE
symmetricOperationRequired NULL
h245Tunneling TRUE
nonStandardControl
nonStandardIdentifier h221NonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data 'E0011200011C3B1C399E0100036774640000002E...'H
tunnelledSignallingMessage
tunnelledProtocolID
id tunnelledProtocolAlternateID :
protocolType "gtd"
messageContent
'49414D2C0D0A4743492C61363238316637636366...'H
5d17h: H225.0 OUTGOING ENCODE BUFFER::= 2080060008914A00042800B500001240013C0501
0000A6281F7CCFAA11DA8021993E309A01CB00CD1D820007000A2A1E0273121100A628BBA4CFAA11
DA8023993E309A01CB3402130000000D4001800B050001000A2A1E0249F7801E400000060401004D
40018012150001000A2A1E0249F6000A2A1E0249F7800100010001800180010010A80180520140B5
0000124BE0011200011C3B1C399E0100036774640000002E49414D2C0D0A4743492C613632383166
37636366616131316461383032313939336533303961303163620D0A0D0A08800600040000000335
0204677464012E49414D2C0D0A4743492C6136323831663763636661613131646138303231393933
5d17h:
5d17h: //38/A6281F7C8021/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x63F53D74, Call Id=38
5d17h: //38/A6281F7C8021/CCAPI/cc_api_get_transfer_info:
5d17h: //38/A6281F7C8021/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=38
5d17h: //38/A6281F7C8021/CCAPI/ccCallDisconnect:
ause=38)
5d17h: //38/A6281F7C8021/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x63F53D74, Tag=0x0, Call Id=38,
5d17h: //37/A6281F7C8021/CCAPI/ccCallDisconnect:
ause=0)
5d17h: //37/A6281F7C8021/CCAPI/cc_api_get_transfer_info:
From your output i could say that setup message was sent but nothing came back.
Check please the IP-address of CallManager, then connectivity between CallManager and voice gateway. If everything is OK, then check if access-list or firewall exist on the way between them.
256
