Erlang to number of VoIP calls
Would like to know, how do you convert Erlang to VoIP calls. Have a requirement for .1 erlang per site usage of VoIP . How do i convert to number of VoIP calls per site.
thank you
Re: Erlang to number of VoIP calls
will this help?
http://www.erlang.com/calculator/
Steve
Please rate all helpful posts.
Thank you. Yes , i have used this site before.Just that it is difficult to quantify the number of VoIP calls, given the per site requirement in Erlang
Any other recommendations ?
I am afraid i am not following you. You have a targeted Erlang of .1 (right?)
How did you arrive at that?
What is your acceptable blocking? 1 per 100?
With those 2 values and codec, you can easily figure out the bandwidth/number of calls.
Steve
thank you.
.1 Erlang was the requirement per site.
customer don't have the acceptable blocking number ? is there a typical blocking number
thank you.
thank you.
I would not say there is a "typical" number. I think it is an issue if preference. What is an acceptable number of calls to receive busy signals at peak times?
Steve
Steve
255
