06-12-2002 07:33 PM - edited 03-12-2019 07:11 PM
I'm getting this error when I'm at the inital web setup screen for CRA. Nothing is non-standard about the cluster.
javax.naming.AuthenticationException: [LDAP: error code 49 - Invalid credentials] (80004005)
I've tried my sa/admin password for the publisher, plus ciscocisco, etc etc.
ideas?
06-13-2002 05:57 AM
Depending on the directory you are using you need to put in the directory user password. If you are using the default DCDirectory then you need to put in the password for the Directory Manager user. Make sure you have the correct info as in the link below.
Just keep in mind this doc says the password is ciscocisco. That is the case if you did a 3.0 install and upgraded. If you install 3.1 first it asked you for the Directory Manager password.
Thank you,
-Mckee
06-13-2002 08:14 AM
Hmmm.. I did a fresh 3.1 CCM Install and the password I used globally for all the PW works fine, but not on the apps box. Perchance does the application engine or DC Directory not like "*"'s in the password or "$"'s?
06-13-2002 09:40 AM
Not sure about that. One thing you can do to verify what or what is not the password. If you look in the registry. Go to HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\Directory Configuration specifically look at the mgrpw. This the password callmanager services are using to login to dcdirectory. So go to a command prompt and type "passwordutils (password you think it is)". This will give you the encrypted version of the password you think it is. If they don't match that is your problem.
Thank you,
-Mckee
