Error message on cmpub in event viewer. Please help
mreilly
Error: kSerialPortOpeningError - Error when CMI tries to open the Windows NT serial port.
Serial Port Opening Error: Windows NT returned an error opening the serial port: ( 5 ) - Access is denied
App ID: Cisco Messaging Interface
Cluster ID: CMPUB-Cluster
Node ID: 10.200.1.10
Explanation: When CMI tries to open the serial port, Windows NT returns an error.
Recommended Action: Make sure the serial port is available..
adignan
Level 8
Level 8
First off, do you have an SMDI integration to your CallManager? If so this is a problem, if not, I would recommend disabling the Cisco Messaging interface. If you do, ensure your serial port is working properly from a Windows standpoint. FOr example, connect the serial port to a router, can you use hyperterminal correctly. This is from the CallManager 3.3.3 Error Message link
Error Message
%CCM_SUMI-CMI-2-kSerialPortOpenningError: Error when CMI tries to open the Windows NT serial port. Serial Port Openning Error [String]
Explanation When CMI tries to open the serial port, Windows NT returns an error.
Recommended Action Make sure the serial port is available.
