==Error messages on Event Viewer== HELP!!
we had an electrical problem, the CM do not shutdown properly and then when ther services come back appeared the attached message:
Disk Error None 7 N/A
The device, \Device\Harddisk0\DR0, has a bad block.
WHAT CAN I DO TO RESOLVER THIS PROBLEM?
1 REPLY
Green
Re: ==Error messages on Event Viewer== HELP!!
Hola Jose,
Run chkdsk on the drive:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/chkdsk.mspx?mfr=true
I would also contact HP|IBM to run the manufacturer's diagnostic in order to know if disk needs to be replaced.
Are you able to access that device just fine?
Or you get an error?
96
