Error when ip phone is busy
I have a Callmanager that uses a gateway 3640 with a ISDN PRI as PSTN access. When there is a call from PSTN to a IpPhone in busy state the caller don't hear the busy tone but a provider's message " the number doesn't exist".
The debugs of the gateway:
deb cch323 h225
deb cch323 h245
Aug 19 10:54:39: H.225 SM: process event H225_EVENT_SETUP, for callID 8BBcch323_
run_h225_sm: received event H225_EVENT_SETUP while at state H225_IDLE
Aug 19 10:54:39: cch323_h225_check_qos_and_snd_setup: Setup ccb 0x63FDE020 callI
D 0x8BB
Aug 19 10:54:39: H.225 SM: process event H225_EVENT_FAST_SETUP, for callID 8BBcc
h323_run_h225_sm: received event H225_EVENT_FAST_SETUP while at state H225_IDLE
Aug 19 10:54:39: cch323_run_h225_sm: Setup ccb 0x63FDE020 callID 0x8BB
Aug 19 10:54:39: cch323_h225_generic_send_setup-- sending calling IE
Aug 19 10:54:39: ======= PI in cch323_h225_generic_send_setup = 3
Aug 19 10:54:39: Send infoXCap 128
Aug 19 10:54:39: src address = 10.226.192.254 of h225SetupRequest
Aug 19 10:54:39: dest address = 10.226.192.6 of h225SetupRequest
Aug 19 10:54:39: H.225 SM: changing from H225_IDLE state to H225_REQ_SETUP state
for callID 8BB
Aug 19 10:54:39: cch323_h225_receiver: received msg of type CALLPROCIND_CHOSEN
Aug 19 10:54:39: ====== PI in cch323_h225_callproc_ind = 0
Aug 19 10:54:39: Other end of call is dropping tunneling.
Aug 19 10:54:39: src address = 10.226.192.254 of CALLPROCIND_CHOSEN
Aug 19 10:54:39: dest address = 10.226.192.6 of CALLPROCIND_CHOSEN
cch323_run_h225_sm: received event H225_EVENT_CALLPROC_IND while at state H225_R
EQ_SETUP
Aug 19 10:54:39: H.225 SM: changing from H225_REQ_SETUP state to H225_REQ_CALLPR
OC state for callID 8BB
Aug 19 10:54:39: cch323_h225_receiver: received msg of type RELEASEIND_CHOSEN
Aug 19 10:54:39: cch323_h225_release_ind: disconnect cause 17 location code 0
Aug 19 10:54:39: src address = 10.226.192.254 of RELEASEIND_CHOSEN
Aug 19 10:54:39: dest address = 10.226.192.6 of RELEASEIND_CHOSEN
cch323_run_h225_sm: received event H225_EVENT_RELEASE_IND while at state H225_RE
Q_CALLPROC
Aug 19 10:54:39: H.225 SM: process event H225_EVENT_RELEASE, for callID 8BBcch32
3_run_h225_sm: received event H225_EVENT_RELEASE while at state H225_REQ_CALLPRO
C
Aug 19 10:54:39: cch323_h225_send_release: Cause = 17 Location = 0
Aug 19 10:54:39: src address = 10.226.192.254 of h225TerminateRequest
Aug 19 10:54:39: dest address = 10.226.192.6 of h225TerminateRequest
Aug 19 10:54:39: H.225 SM: changing from H225_REQ_CALLPROC state to H225_IDLE st
ate for callID 8BB
Thanks in advance
Giovanni
Silver
Re: Error when ip phone is busy
This look more like an IOS bug to me rather than anything else. Check for any known issues in the version that you are running using the bug toolkit.
I upgrade the router to version 12.3.2-t1 but the problem is the same.
Can you post output of "debug isdn q931"?
The busy ip phone, you are trying to call, is it forwarded on busy to some other number??
Is call waiting enabled on the busy ip phone??
the phone is configured with no forwarding on busy and the call waiting is default. In the CallManager's Service parameters the Call Waiting Enable parameter is set to False. This setting is required from the customer becouse he want only one call at time on the phone.
Follow the q931 debug:
Sep 9 13:58:05: ISDN Se3/0:15 Q931: ALERTING pd = 8 callref = 0x804C
Progress Ind i = 0x8188 - In-band info or appropriate now available
Sep 9 13:58:09: ISDN Se3/0:15 Q931: SETUP pd = 8 callref = 0x004D
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1838D
Preferred, Channel 13
Calling Party Number i = 0x0181, '3482511643'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '458871671'
Plan:ISDN, Type:National
High Layer Compat i = 0x9181
Sep 9 13:58:09: ISDN Se3/0:15 Q931: CALL_PROC pd = 8 callref = 0x804D
Channel ID i = 0xA98389
Exclusive, Channel 9
Sep 9 13:58:09: ISDN Se3/0:15 Q931: DISCONNECT pd = 8 callref = 0x804D
Cause i = 0x8081 - Unallocated/unassigned number
Sep 9 13:58:09: ISDN Se3/0:15 Q931: RELEASE pd = 8 callref = 0x004D
Cause i = 0x82E31E - Information element not implemented
Sep 9 13:58:09: ISDN Se3/0:15 Q931: RELEASE_COMP pd = 8 callref = 0x804D
Sep 9 13:58:10: ISDN Se3/0:15 Q931: DISCONNECT pd = 8 callref = 0x80A8
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
The issue is solved, in the configuration there was this parameter "disconnect cause 1" that generate the issue.
Bye
Giovanni
306
