Errors running Bulk Import - 4.0(2)
UM 4.0(2). Off-box E2k message store with seperate DC svr.
We're importing users into a new install of UM using bulk admin. The subs have imported ok & the appropriate AD & Ex2k accounts have been created on the respective svrs. Tests with sub logon & leaving messages are ok so far.
I've noticed alot of errors in my event log on the Unity svr that occured at the time the bulk import tools was run. The events are 30012 followed by 30007 occur instantaneously with the source of CiscoUnity_MALEx & the AvMsgStoreMonitorSvr. The fix on support.com refer to the AvCsMgr service not having the correct permissions. The account that runs this service has not changed & the fix does not refer to my scenario or version of Unity.
Has anyone else experienced similar errors when importing users in Ex2k? If so need I be concerned & if I should what steps do you recommend I take?
Thanks for any help & suggestions in advance folks.
Cheers,
NJ.
200
