Ethernet errors on 7912 PC port
I am trying to solve an issue where the attached device on the PC side of a 7912 is not able to connunicate with the network.
Any idea's.
1 REPLY
Re: Ethernet errors on 7912 PC port
Mark,
Start looking at the switch port config.
for a ios based switch, with a separate voice and data vlan, your config should be,
int fa0/1
switchport mode dynamic desirable
switchport acesss vlan 100
switchport voice vlan 101
spanning-tree portfast
(excluding any qos configs).
Make sure vlan 101 is able to communicate to the rest of the network.
Also Do you see any duplex, speed errors on the phone port ?
Sankar
PS: please remember to rate posts!
117
