10-27-2006 05:52 AM - edited 03-15-2019 04:41 AM
Hello Guys,
I have 7960 phones with Expansion Module but can't see the 14 lines in the CCM Administration Page. When I reboot the phone I see the buttons on the Expansion Module go red and back to the normal but it doesn't show in the CCM Administration page. Could someone please help?
10-27-2006 06:04 AM
In CCMAdmin go to Device --> Phone, search for the 7960 that you are using. Make sure that under 'Expansion Module Information' you have selected the 7914 14-Button Line Expansion Module.
Reset the phone to take the changes
10-27-2006 06:16 AM
That's exactly what is configured for the phones but it doesn't show the lines for the expansion module.
10-27-2006 07:36 AM
Hi Bahman,
Have you checked that the button template you are using is set up properly for the 7960 and 7914. Have a look at the following doc;
Hope this helps!
Rob
