Extension Mobility - 2 Lines?? Is it possible?
Hi Guys.
Is it possible for a User Profile to contain 2 Lines when logged in to Extension Mobility? I have a user who has 2 line one for her General Use and One as a Reception Overflow. When I set her up in EM, when she logs in she only gets one of the Lines.
Anybody any Ideas?
Many Thanks
Dave
1 ACCEPTED SOLUTION
Re: Extension Mobility - 2 Lines?? Is it possible?
yes you can,
but create a 2-line 7940 Phone Button Template,
and set that as default in the Service Parameters of the Cisco Extension Mobility Logout.
But this is a global setting, so for everyone who logs in onto a 7940 will get 2 lines...
In other words, if a user has 1 line/1 speed dial and logs onto a 7940, the speed dial is gone....
I'm thinking you're using a 7940 phone for her to login to and you have the service parameter in the Extension Mobility Logout service set to "standard 7940" which is a single line 7940 profile.
Make sure you have a 7940 profile that's configured for 2 lines and set the service parameter to your 7940-2line profile.
When she logs in, she'll get both the lines appearing.
Thanks for that i'm sure it will work but i'm unsure where I set the service parameter in the Extension Mobility Logout service set to "standard 7940".
Could you point me in the right direction?
Dave :)
Hi Again,
I've just read that "Only the IP Phone 7960-based user device profile may be added in Cisco CallManager 3.3 (2)." Does anybody know if you can still get 2 lines on a 7940 using a 7969 profile? I just get 1 Line and A Speed Dial. Even if No Speed dials are setup. Just the 1 line.
Anybody?
Dave :)
yes you can,
119
