10-08-2003 11:24 AM - edited 03-13-2019 01:58 AM
Can I use Console Attendant with Extension Mobility in CCM 3.3?
Can I use Console Attendant with share lines as Web Attendant?
Can I use Web Attendant with CCM 3.3?
10-08-2003 03:51 PM
AC with EM - Yes.
AC with shared Lines - Not supported
WA in CM 3.3 - Default it comes with AC. WA cannot be configured.
10-08-2003 04:22 PM
But in:
says: "Cisco CallManager Extension Mobility cannot be used with Attendant Console."
Thats true?
10-09-2003 12:24 AM
Due to the fact that Extension mobility uses a shared line (shared between the "logged-in" phone and the user device profile), you cant have a phone configured for EM as the associated device for Attendant Console, as AC doesn't like shared lines. You can however have the phones used for Attendant console operators configured as non-EM devices, and have fixed DN's on the lines. AC works fine with this configuration. Extension Mobility can be configured on a device by device basis, it's not nescessary to have all devices as EM devices.
HTH.
Bill.
10-09-2003 04:31 AM
Thanks for your explanation. Even in that configuration I can not monitor IP Phone who have EM activated?.
Alex.
10-09-2003 07:54 AM
Hi Alex,
When you use AC in en EM scenario, as long as you use the AC without shared lines, in the AC application itself, you can still monitor the users and devices that are logged in, so you can still see line status etc of your users on the AC application. AC and EM are not mutually exclusive, it's just shared lines on the device AC is associated with that is not supported.
Bill
