Extension Mobility - desktop shortcut 3.3
Customer used to have a shortcut to log in via extension mobility without having to log in to the phone (unsupported i presume ;)). Does anyone know what the link is with CCM 3.3?
Cheers
Re: Extension Mobility - desktop shortcut 3.3
there is a API for Extension Mobility and you are allowed to connect to it. You can get the description for the API on the cisco pages.
We use for example the following HTML-file:
IP-Telefon
Kind regards,
Axel
Hi;
i cant understand what do you mind
Instead of going through the menu on the phone to login to extension mobiliey, all you need to do is double-click a shortcut on your desktop to log into the phone. Cheers
216
