Extension Mobility - desktop shortcut 3.3
jocoates
With CCM 3.1 and 3.2 We used to be able to use a shortcut on the desktop on the PC to log in to our phones via extension mobility.
Format of shortcut to log in was
http://10.120.250.10:8080/login?devicename=SEP000C303B2644&userid=jcoates&seq=12345
We are trying to do the same thing with CCM 3.3. Does anyone know the format of a shortcut to do this?
I have dug around in the IIS and can't seem to figure it out.
Cheers
sbilgi
Level 5
Level 5
You can see in Cisco BugToolkit to find if there is any bug assocaited.
mwinckless
For auto login or single sign on to extension mobility from the PC try emlogon from linear-seven.
http://www.linear-seven.com/
spectra-ts.nl
Hi, the format is still the same. Check if the IP address (http://10.120.250.10) and port (8080) are still the same on your new config. The IP should point to the extension mobility server (in most cases the publisher) and port by default is 80.
To create the shortcut, just right click on your windows desktop and click new, create shortcut, then enter the url and click finished.
