Extension Mobility in CUCM 7.1: How to send Userid and Pin with Service Par
Hi at all
is it possible to configure the IP Phone Service (CUCM 7.1)for Extension mobility so that when a user login in EM they dont need to insert the UserID and UserPin???
I think it could work with the Service Parameter but I dont know how.
Have somebody an idea?
Thanks.
kind regards
José
1 REPLY
Re: Extension Mobility in CUCM 7.1: How to send Userid and Pin w
Hi!
As far as I know that's not possible and it will defeat the purpose of using Extension Mobility as anyone could login from a phone with no credentials. Porbably you could configure a script or something that allows you to accomplish this, but it won't be supported.
Teresa.
If you find this post helpful, please rate! :)
Regards, Tere. If you find this post helpful, please rate! :)
292
