Extension Mobility issue?
How can setup Extension Mobility so that one user can automatically logon one site to use this site's extension number, but logon other site to use other site's number?
I can setup two device profiles for the user, but the user still needs to
select which device profile to use once he logs in. That is not exactly what we
want.
Green
Re: Extension Mobility issue?
Hi Yun,
Im not a EM especialist, but I would post this in the Developers section, they can help you in how to customized/add the XML files to have an intermidiate page that allows you to select the Device profile/Location/Extension you want to use/ or to associate it automatically based on IP/Device name.
I can only think about 2 users/profiles.
Hi HTH,
thanks for your idea, do you have any reference link?
thanks,
Yunming
106
