Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Extension Mobility: logged out user and external call
Hi all,
I have implemented succesfully extension mobility on a Call Manager cluster 4.1 with over 300 users.
Now my customer ask this: when a user is logged out, if someone call the directory number (7811) or the geographical number that will be translated in the directory number, the caller hear the fast busy tone and the call is dropped.
There is some way to automatically forward the call directed to a directory number of an extension mobility user that is logged out to another number, without using the call forward all under the line of the device profile?
Thanks!
1 REPLY
Re: Extension Mobility: logged out user and external call
if you have 4.2(x) or 6.(x) use the call forward unregistered, if not then you will need to use CFA
java
if this helps, please rate
java
www.cisco.com/go/pdi
368
