Extension mobility on 7961 and 7975
I am looking for assistance on Extension Mobility. We currently have several sites with different phones. When I try to log in to Extension Mobility on a 7975 with the profile as a 7961 I am only seeing the first 2 line appearances, but on the 7961 it is working fine. Is there a way to setup a universal login for every model so the users can login to both 7961 and 7975 without issue?
Thanks for any assistance.
Jason
1 ACCEPTED SOLUTION
Re: Extension mobility on 7961 and 7975
you need to configure default device profiles for each and every model you plan to use, that is covered under the EM guide
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
javalenc
java
345
