External Call to Hunt Pilot not receiving Busy Tone
I have
Line Group - 3 lines
61620
61621
61622
options
No Answer - Try next member but do not go to next group
Busy - Stop hunting
Unavailable - Try next member then go to next group.
The next group is one line used as an alerting phone if no one is logged into the hunt group.
Hunt list - contains line group
Hunt pilot -
61600
Forward hunt no answer - 69916 (unity call handler)
Forward hunt busy - blank
When all lines in line group are busy and I ring pilot 61600 from an internal extension I get busy, however if I ring from an external number I get ringing and the call disconnects after the carrier timeout.
Does anybody know how to get busy to the external caller.
Anthony
1 REPLY
Green
Re: External Call to Hunt Pilot not receiving Busy Tone
The same issue for DN which are busy or only the HP?
If the GW is H.323 you may check this link:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080111b58.shtml
/Gonzalo
189
