Community Member
External Memory Card for cisco3725
I have an partnumber 'MEM3725-64CF-EXT' (64MB External Compact Flash factory upgr) and don't know, if this memory could be used in slot0 of this switch.
(no pictures found on cco).
Thanks in advance
Ruedi
Silver
Re: External Memory Card for cisco3725
MEM3725-32CF and MEM3725-64CF can be used with the 3725. You can use the service parts tool to figure out which part is compatible with the router. Here is the link if you need it in future.
http://www.cisco.com/cgi-bin/front.x/agents/svo_tools/SVOToolDispatcher?FRU_QUERY=QUERY&SID=
Community Member
Hi, I found solution: This flash cards can used inside of router and in slot0: as well.
Ruedi
84
作成コンテンツを作成するには してください
