Community Member
Fail-over system keys
I am setting up a fail-over server for one of my client. The primary system has the parallel key whereas the new one has a USB key. Would we have any issues with this setup? (or does it care at all?)<br><br>Systems Engineer
1 REPLY
Anonymous
N/A
Re: Fail-over system keys
Shouldn't care. So long as the "failover" feature is programmed on one of the keys this should work fine. The Unity server itself is not aware of the key format, it just talks to the Sentinal driver to get the data programmed on the key.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
97
