Failed calls "stuck" in Cisco AS5300
My company uses a Cisco AS5300 as a voice gateway. I have noticed that failed calls sometimes get stuck in the beggining of the "show call active voice brief" command. This is happening only with TDM call-legs and so far the only way to get rid of this is reloading the box.
For example:
datacom#sh call active voice brief
<ID>: <start>hs.< ..... ... .....>,<t120 pkts>/<t120 byt
es>
Total call-legs: 59
3025 : 32053140hs.1 +-1 pid:5 Answer connected
dur 00:00:00 tx:0/0 rx:0/0
Tele 1:1:79898: tx:18130120/1813012/0ms g729r8 pre-ietf noise:0 acom:0 i/0:-79
/-79 dBm
1B9B : 33466590hs.1 +-1 pid:5 Answer connected
Tele 2:3:87849: tx:0/0/0ms g729r8 pre-ietf noise:0 acom:0 i/0:0/0 dBm
1C29 : 33473546hs.1 +-1 pid:5 Answer connected
Tele 3:4:87957: tx:0/0/0ms g729r8 pre-ietf noise:0 acom:0 i/0:0/0 dBm
and then the router shows the real active calls...
Why is this happening and what do I do to solve it?
Daniel Galvao
  • Other Collaboration Voice and Video Subjects
1 REPLY
Bronze
Re: Failed calls "stuck" in Cisco AS5300
May be debug vtsp should give you a better clue on this problem. Did you try this?
109
