Failing incoming Calls
Hello all, We've got a strange problem. We're running a CallManager 4.1(3) with H323 Voice Gateway. Especially for incoming international calls we get lots of problems. Incoming calls where the foreign local PSTN provider sends along the Calling number FAIL. If the foreign local PSTN provider doesn't send the calling number alongn, the call is treated correctly by the Voice Gateway! In attachement you can find an example! I would think that no routing occurs on the calling number? In attachement you can also find our config! Thanks in advance
1 REPLY
Re: Failing incoming Calls
Seems to be a Telco issue, because when you are not sending the Type you receive all the digits but when you are sending the type you do not receive all the digits hence the call is not completed.
131
