Fast Busy on answer, call dropped on dial out
We are having a problem with a 2821 and H323. When you call in, the phone rings but the call is dropped on answer, with the internal phone ringing fast busy. On call-out, the other end rings once then goes to fast busy.
I suspect a DSP issue. There are 2 32 channel PVDM2 cards on board, no no issue there. Is there some extra step to enable DSP use on this router? We normally use 2811's which I thought were nearly identical.
Configuration is below, thanks in advance.
David Martin
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
voice-card 0
no dspfarm
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
controller E1 0/0/0
pri-group timeslots 1-8,16
interface Serial0/0/0:15
no ip address
no logging event link-status
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:15
no vad
cptone GB
dial-peer voice 9 pots
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
dial-peer voice 100 voip
preference 1
destination-pattern 66101...
modem passthrough nse codec g711ulaw
voice-class codec 1
voice-class h323 1
session target ipv4:xxx.xxx.xxx.xxx
incoming called-number .
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 200 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:yyy.yyy.yyy.yyy
fax rate disable
no vad
num-exp 251... 66101...
1 REPLY
Blue
Re: Fast Busy on answer, call dropped on dial out
if you do require DSPs then YES, you are missing quite a bit of DSP configuration info.
please see the following link for more info on DSP configuration for CME/IOS:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00806a8015.html
CCM SCCP Bound IOS DSPs -
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
173
