Fax (ATA-186) does not receive calls from ISDN fax machine
we saw incoming this messages on the isdn deb:
*Apr 4 11:23:51.414: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x11
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Calling Party Number i = 0x00A3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0xC1, '59'
Plan:ISDN, Type:Subscriber(local)
Low Layer Compat i = 0x8890
High Layer Compat i = 0x91A1
*Apr 4 11:23:51.430: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x91
Channel ID i = 0x89
*Apr 4 11:23:51.846: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0x91
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Apr 4 11:24:03.966: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x91
Cause i = 0x80AF - Resource unavailable, unspecified
*Apr 4 11:24:04.118: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x11
*Apr 4 11:24:04.118: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x91
*Apr 4 11:24:12.030: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x10
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Channel ID i = 0x82
Progress Ind i = 0x8083 - Origination address is non-ISDN
*Apr 4 11:24:12.042: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x90
Channel ID i = 0x8A
*Apr 4 11:24:12.462: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x90
Cause i = 0x8091 - User busy
*Apr 4 11:24:12.638: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x10
*Apr 4 11:24:12.642: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x90
the 1. try is an unrestricted digital call, fax on ATA respond, but the isdn send out a disconnect. fax still waiting.
After 10 sec. the isdn fax will start a new call with Audio, but the fax on ATA seems to be not ready for a new call.
Any solutions on this or best practice.
many thanks
regards August
Re: Fax (ATA-186) does not receive calls from ISDN fax machine
Hello August,
is your fax machine using G4?
As far as I know, this is not supported with ATAs.
The maximum supported Fax-Standard is Super G3
Hope this helps.
Cheers,
Geri
Hello Geri,
Yes it is a G4 Fax in the First try.....second one it is a G3 (G4 has switched to G3) but the ATA186 is busy (because the Fax Mashine try again after 10 sec.)!
May there is a timer in the ATA186 how long it is busy when the Call has alrady finished?
cherrs
Christoph
323
